cancelar
Mostrando los resultados de
Quiere decir:
Easily Add Drafting Views to Sheets
It would be nice if there was a way to easily add "Drafting Views" (or any type of view) to sheets using a one-click method. Instead of having to drag the view to a sheet, if there happened to be a way we could right-click on the view and have an option to "Add to Sheet." A dialog box could appear and you have the option to either add it to an existing sheet or to a new sheet. After you select new or existing sheet, it would send you to that sheet and allow you to place it where you would like it to be placed.
2 Comentarios
lionel.kai
duplicate idea: right-click to add a View to a Sheet
similar idea (ALL open views): Place open views on sheet
Maltezc
Hi there, I created a plugin that i think could help you with this.
It allows you to place views on a sheet incredibly fast.
huge time saver.
check it out here:
https://apps.autodesk.com/RVT/en/Detail/Index?id=9040274247571226768&appLang=en&os=Win64
Enviar idea
