Dynamo Player "Play" Buttons Should Be Disabled If Another Command Is Active
Commands in the ribbon that are not allowed to run while another command (such as the Wall or Detail Line) is active are grayed out and cannot be clicked. The "play" buttons in Dynamo Player, however remain active and clickable even though running a Dynamo script while another command is active is not possible. Dynamo Player should either disable the play buttons at this time or provide some mechanism for scripts to interrupt or cancel out of an active command.
Forma Design Contest
Technology Administrators
