DWG export allow double lines
Adding of an option to allow superimposed lines in export
Unfortunately an enormous data loss is caused by the reduction to visible layers.
For reinforcement exchange areas lying below are required or are directly adopted to be able to illustrate reinforcement.
For dissemination to third designers (subsections, facade designers, plumbers….)
deactivate reduction to printable lines
e.g. in Export Setup Tab  / General at the item Default export options
Checkbox: export Double Lines
BR René
4 Comments
sasha.crotty
Is this the setting you are looking for?
sasha.crotty
  The setting was added to Revit in 2015 R2 release. Marking as implemented.
Tarek_K
Status changed to: Gathering Support
Tarek_K
