Can we have the Duct, Pipe, Duct Fittings and Pipe Fittings associated to levels in the same way please.This is one of the first things I brought up with an Autodesk rep when I first started using Revit in 2007!
Curently if we have say Ductwork associated to the wrong level and want to change it we select a duct element and change the associated level - the duct element will stay where it is and the offset will change to match the new level, all good right. But if we do this to a duct fitting then the fitting (and everything attached to it) will move to the new level with the same offset, you have to work out what the new offset should be and type that value in to keep the element correctly located. I would rather it work the way it does with the duct elements (so I can select all and change in one go) but as long as they both work the same way it would still be better than currently.
