cancelar
Mostrando los resultados de
Quiere decir:
Drone View
Drone View
I would like a drone video. You could pick points in a random path around the project. Each point you pick would have an elevation and a camera angle. It would draw a path between points and the path could be selected and you could set speed (Speed up on some paths and slow down on others).  As it moves from point to point along the path camera pans it's view from the aiming point on point #x to the aiming point on point #y.
1 Comentario
solonet
sinto necessidade desta ferramenta, DRONE VIEW, que acho fundamental para
VISUALIZAR um projeto para uma obra por exemplo, sugiro ainda que o drone VIEW
SEJA CRIADO NO 3D
obrigado
DANIEL
SOLONET@SOLONET. ENG.BR
Enviar idea
