cancelar
Mostrando los resultados de
Quiere decir:
Drafting view phase
Drafting view phase
It would be nice if you can assign a phase to a drafting view. Being able to assign a phase to a drafting view would make for easy sorting and grouping when doing multiple phases within a single model. Right now if you sort your project browser by phase drafting views will always be under "???" because that parameter doesn't exist. The only workaround is to use a text project parameter for a views
3 Comentarios
stefan_gokstorp
Drafting view only allow for 2d object which is unbound by phases. why would you need phases for this?
if you want to sort them use view sorting parameters withing your project and Browser orginization on the views.
Reed_Weinstock
@stefan_gokstorp You are correct with about drafting views being unbound by phases and definitely don't want that changed. The benefit of being able to associate a drafting view to phase for would for more efficient sorting of views in the project browser and view schedules for models with multiple phases.
HVAC-Novice
You can just add a parameter to the views and sort by them. Like make it a integer or text parameter and then sort views by that parameter. Make phase 1 start with "1"or "A" and so on. Details used in multiple phases could just start with 0, or X or something that makes it neat looking in your browser.
If Autodesk adds phases to 2D views, it will make it more complex for anyone not wanting this. I suspect that is the majority.
I don't work in many phases, so my experience is limited. But I suspect many details will be the same in all phases. For example, if you have a detail about how to install a window, that would be the same for all phases.
Enviar idea
