Double click to edit text
Double click to edit a text.
It seems logical, but apparently, not for revit.
The thing is that to be able to do it, you have to firstly select the text. Then double click.
What a waste of time (so you think you are in editing mode, you push delete, aaaand, it's gone...)
And i notice that you can delete object with the backspace key, exactly like the del key. Nothing logical at all, as any other software use it like that.
2 Comments
fruity101079
Ok it seems more complex than i thought (of course, it's revit).
Sometimes it's working, sometimes not. Why? I don't know.
But what I discovered is that if you don't zoom in enough you won't be able to do anything with your text note.
You can double click thousand times, nothing will happen.
So i was looking for the edit icon in the ribbon, but there is no one!
Maybe right click? no more.
So i was looking for the command name to assign it to a shortcut, and guess what, there is no command!
How is it possible?
Disappointed
Maybe it is a feature to hinder the use of text notes and stick with annotations?
