cancelar
Mostrando los resultados de
Quiere decir:
Disable Filter
Disable Filter
The Enable Filter column is currently active or not
All columns of each filter are editable. This is not good in the list of many filters. Better when Enable Filter is off Deactivate the rest of the columns of the filter and make it gray.
3 Comentarios
tl
And it would also be grate to make it possible to select multiple lines, to enable or disable multiple filters at once.
GHASEM_ARIYANI
Hello @tl
in Revit 2022 you can select multiple Filter Line and can change
jkarben
I agree. If the filter is disabled (Enable Filter unchecked) it would be nice if the filter name was greyed out. However, I would prefer that all columns remain editable.
Enviar idea
