Dimensioning to the center of a curve radius is critical to provide information to a contractor on where to locate curves when building. Currently the only way to dimension to a center of a radius in a modeled element is for radial walls, with "Center Mark Visible" checked in their properties. This is unsatisfactory for several reasons:
The work around is to draw a dumb set of lines to dimension to, but this requires careful coordination, and doesn't update as the model does.
The center mark of a radial dimension should be able to be dimensioned to, the same way a point on a wall corner might - tab to highlight. Ideally there would also be a provision for demensioning to the center mark when a radial dimension isn't present, perhaps hoovering over the curve and tabbing to select.
