Dimension Labels
Dimension Labels
Be able to select multiple room dimensions and tag them with the same name rather then double clicking every dimension manually. Or have the ability to link the room name underneath the dimension string name as an instance or type parameter to be either turned on or off.
Also the ability to change the font size/style of the description text (not the dimension value) so the prefix, suffix or under the dimension string section.
