It sure would be nice to have a quick way to merge duplicate styles to clean up a project.
I put a lot of effort making sure my template is clean and pure, but when it comes to a real project, things get messy fast.
For example, I may end up with linestyles called "Heavy", "HEVY", "HEV", "HVY" and "Lineweight 4" as a result of copy and paste from other projects, downloading from the web, and giving the intern redlines. I know they should all be the same, but there is no easy way to merge. I cannot select all instances in project for lines (bummer) and if i have 100 details, it will take forever to select and change type for each view. I can delete the bad line styles, but then they all end up Lineweight 1, which does not print they way i want.
Same issue with Fill Patterns, Filled Regions, Text Styles, Dim Styles, etc.
