Detail Lines with Arrowheads at one end / both ends
I would love Detail Lines with Arrowheads at one end / both ends, just like in Word or Excel.
5 Comments
Mike.FORM
This is technically possible for the single end version as text notes can be blank. This was added a few versions ago but I cannot remember which one.
Mike.FORM
You can also create a generic annotation family that only contains a vertical invisible line in it and then add leaders to that.
@Mike.FORM I need a diagonal line with arrowheads at both ends and a short text above the line at the middle. (e.g. slab height = 20cm). I also need the text to automatically rotate and align with the line, no matter how i stretch or rotate the line. I created such generic family but i never managed to make the text to automatically reposition and align with the line.
It is easier to do it "Autocad-style": a diagonal dimension line with arrowheads and override the dimension's numerical value with desired text.
Mike.FORM
This is a line based detail item family that does what you want. The text and arrow heads are nested, locked to ref planes, and they adjust based on the scale parameter.
I cannot attach family files in the ideas forum but if you create a post in the revit forum I can upload it. Or you can try to build it yourself.
JEggen42
Just like the straight line, select line, and curved line options, a draw line with arrowhead option in the detail lines tool would be useful.  There are definitely work arounds, but the option to add arrowheads to a line would speed up the process.
