Detail lines in locked 3D view
The idea is to create detail lines in a locked 3D view.  As sometimes this makes more sense than 2D plans.
And as everybody encourages you to work in 3D, why is it not possible to create 3D details with extra information?
2 Comments
Disappointed
While I would not mind having detail lines enabled to annotate locked 3d views, for now you can always put the annotations into the sheet you are putting your locked view on. Perhaps you could mock up what you have in mind in paintbrush to illustrate your idea?
Atafs
I don't think this is needed as there is a simple work around this which i used in the past and it achieves the same thing you wanted.
Add a 3D view to a sheet then draw the lines, texts you wanted. if you only want the view then just delete the tile block. that's it!
