In Revit, there is a bunch of useless pop-up windows.
But when deleting a parameter that is used in a formula, we don't get any information, and that can break Families, as shown in the video:
We should get an pop-up that we are about to delete a INSERT_PARAMETER_NAME_HERE.
Also, I think that the value of the parameter should stay after the parameter is deleted:
example:
# Parameter still available:
#Parameter (in this example "Luft Lima") deleted and its last value transferred to the formula:
*If it's an Instance parameter, the last current value should be set, but if it's a Type parameter, the value should vary by type.
