Show only
Search instead for
I want you to be able to make a vertical surface on the toposurface (you can place two internal points with the same XY and different Y) On the toposurface, the current vertical plane cannot be created, but such a part comes out when calculating the toposurface. In order to take advantage of REXJ's ground calculation tool, I think it is necessary to allow XY to place the same internal point at two points. Thank you for your support.
