地盤面で垂直面を作れる(XYが同じでYが異なる内部点2点を置ける)ようにしてほしい
地盤面では、現状垂直面が作成できませんが、地盤面算定の際にはそういった部分が出てきます。
REXJの地盤算定ツールを生かすには、XYが同じ内部点を2点置けるようにする必要があると思います。ご対応よろしくお願いします。
1 Comment
English Translation:
I want you to be able to make a vertical surface on the toposurface (you can place two internal points with the same XY and different Y) On the toposurface, the current vertical plane cannot be created, but such a part comes out when calculating the toposurface.
In order to take advantage of REXJ's ground calculation tool, I think it is necessary to allow XY to place the same internal point at two points. Thank you for your support.
