In my project, when cutting a section at Level 2, the crop region of the section does not show the structural framing from Level 2, the level the section is cut from, but from the level above (Roof). The crop region of the section stops just above Level 2, at the Top of the Primary Range of the Level 2 view (see image 1). However, if I remove the wall from the model along this grid and cut another section at the same place, the crop region of the new section now shows the structural elements from Level 2 as expected, all the way down to Ground Level (see image 2). the section should consider Structural Framing as part of the elements to show or at least change the section crop region to match View Range from the level the section is cut from.
Here's the link to the Revit Product Forum about this subject: Why do sections behave differently when a wall is present?
