Customize steel objects for Advance Steel Extension into Revit Interface
The request is to be able to edit/add steel objects in Revit directly, without the need of Advance Steel.
The workflow now is:
  • Edit/Add in Advance Steel - Management Tool
  • Copy the specific database after that, from Advance Steel dedicated folder to Revit dedicated folder.
For example: Add a new bolt diameter or a new length for Anchors.
1 Comment
ipselute
So why not create a "common resources" folder for both Revit and Advance Steel? Like a custom Autodesk library. Common database will make future transition from Ad. Steel to Revit easier (supposing Revit would replace Ad. Steel eventually).
Forma Design Contest
Technology Administrators
