Customize "[No Slope]" value in Spot Slope tag & Change default "UP", "DN" text in Stair Paths
  • Allow for customization in Spot Slope to [No Slope] value/text, to comply with other standars or language.
  • Add the ability to assign a different default values to Stair Path by type, default are "UP" and "DN", and the user have to select it to change per instance each time.
  • Ramp path should work similar to Stair Path, current behavior is not good at all and only shows the "UP" or "DN", but no arrows or path at all.
1 Comment
_dalewfd
Agreed. Forcing everyone to use the default 'UP' text every time a stair is created, with no way to change the default behaviour is mega annoying.
