Customizable sheet name in project browser
Would it be possible to have a customise the the parameter referring to the name in the Sheets section of the project browser?
Currently it is covered by the built-in "Sheet Name", but it would be quite useful if it could be modified to fit in together more content, like a label allows you.
As an example, the image below shows a custom sheet name form by the built-in parameter "Sheet Name" and 3 other custom parameters "Sheet Name2/3/4". But then in the project browser it is only reflected the "Sheet Name" one.
Maybe adding the option in the browser organization menu?
2 Comments
Hi, @adolfomoncayo ,
Is this similar to what you are asking for?
ola6n4qrvdsr
You could also try adding custom sheet labels as a shared/project parameter to your schedule and apply to all sheets, then adjust browser organization to suit.
