cancelar
Mostrando los resultados de
Quiere decir:
Correct colors!!!
Correct colors!!!
Architects and interior designers need more than just functional program. They need to work with a color but this is unrealizable with Revit, so user has to use 3ds Max even to see the color that is assigned to the object.
How colors change - https://youtu.be/RXyw2DnVGKg
Possible solution of this issue could be creation of a new view “Diffuse” with special properties:
  1. Switch off all highlights effects;
  2. Switch off Bamp;
  3. Switch off shadows of the edges;
  4. Switch off textures;
  5. User can control the main shadows of the object
Thereby we will get an additional view with materials colors from section “visualization”.
6 Comentarios
No aplicable
Misprint: Textures should be.
pieter1
 Completely agree! I have made a duplicate idea by accident about this: https://forums.autodesk.com/t5/revit-ideas/consistent-colors-mode-with-textures/idi-p/7931742
I will ask the moderators to merge my idea into yours!
I have also created a document that explains the problem in more detail:  https://www.dropbox.com/s/y5o9p0r9b8z8yt8/Revit%20Test%20Scene.pdf?dl=0
pieter1
Also, I assume that you meant that textures should be ON in this "diffuse" mode, right? Otherwise it would be the same as "consistent colors"?
No aplicable
That's right, it was a typo.
pieter1
No aplicable
This is my #1 request. We need this for design.
Enviar idea
