cancelar
Mostrando los resultados de
Quiere decir:
Copy Monitor
Copy Monitor
When using copy monitor if the item that is copy monitored changes the item should change or move.  Example MEP and structural typically copy monitor grid and sometimes levels.  If the copy monitored grid or level name or number changes the corresponding grid or level that was copy monitored should change the name or number.
1 Comentario
Kimtaurus
When an monitored element in a linked files is moved or changed in any way, you'll get a message saying a monitored element has been changed. Opening the Coordination Review window will give you a list of changes. When you approve them, the element in your model will change as well.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Enviar idea
