Copy Legend Views between two projects or templates
Copying Legend Views between two projects or templates is currently a manual process. Enabling this feature will make it easier to generate a Revit Project Template from a finished project, thus saving many hours or even days of work.
3 Comments
ipselute
@Anonymous: I'm 100% with you, bro.
Mohamed-Nassar
in Revit 2021 this problem had been solved Sir hope to try it and give us your Feed back.
Best Regards,,
Mohamed Nassar
Basam.Yousif
Revit 2021 solved this issue, and there are Dynamo scripts for older versions.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
