Control over cable trays width
Usually, here in Brazil, cable trays width is measured from the inner side of the lateral frame, this lead us to some strange values and we need to create extra parameters to report the appropriate size, since Revit considers only the outer measure.
2 Comments
xMD7x
It's the same here in Canada. Cable tray width is determined based on the inside width.
Would be nice if Revit determined width based on inside dimension and if we could also determine rail width (maybe through MEP settings to make it global).
TomD-Clearwater
Community Visitor
be able to either modify or add parameters to containment systems ladder tray.. ect.
currently revit draws containment at the same size as its tagged i.e. 300 ladder is only 300 wide however some manufacturers actually produce 300 ladder that is 344 wide (similar with all sizes).
it would be helpful to be able to differentiate between outer width and rung with
kind regards
Tom
