Control Grid Line Extension in Cropped View
This idea has been created on behalf of users
The idea would be to somehow add more controls on grids and levels extents lengths on sheets
Indeed, they often end up in the situation where the grids / levels extents go way beyond the views crop regions limits.
This leads to a waste of paper available for printing purpose.
The only solution so far is to manually adjust levels and grids length for all views included in the sheets which is a time consuming task.
30 Comments
Can we please have the ability to set the default Grid Extension (default ~25mm).
Ideally this would be part of a View Setting than can be control Via a View Template. Across 1000's of views moving grid 2d end points is painful especially when I know the default is 25mm and all I need is 15mm etc.
There are ways to automate this, via the API and Propagate Extents, but this should be a setting that is automatic, no thought...
You mean like how far outside of the crop region that the column grids should extend? Yes!!! Especially desired for linked files.
Yes!!! Please Autodesk, we need this.
It's such frustration work having to drag every grid end on every view closer to the detail... 25mm offset is way to much.
ipselute
An Autocad Stretch command would solve that problem in less than 2 seconds (using cross-selection method, of course). So sad Revit doesn't have a Stretch command.
magnus
Currently I am working on a large project with several hundred sheets containing views (scope boxes), all have grid lines that need adjustment...
Apparently propagate extents does not solve this (by design).
I have not been able automate this process, a long manual and soul crushing process awaits me 😞
Dynamo? no luck(yet), macros? no luck... Google? no luck...
This is the most  basic layout work!
Please... Autodesk, make this a priority!
p.s. My life has to be more valuable than spending it on this?
Check out Bonus Tools tool 93. I developed this to get around the problem by automating the aligned based on a template set of views, saved me weeks/months on 1 project!!!
magnus
Thank you Chris! I will be sure to check it out!
W_Whit
Please make this happen! How is this not a simple addition to the View Templates?
twellins
Grid bubbles extend slighly past your crop view.  Ideally we would like them to snap to the boundary of the crop view.  Or at least a project configuration for grids
Tags (1)
darwin_valenzuela
Any type of precise control over annotation objects would be welcomed.
pieterdewaal
We use scope boxes a lot to control the crop view regions of plans; however, the grids always extend too long. Having the ability to set "grid offset" and/or "level offset" from said crop region would be a tremendous time saver.
Propagate Extents is a partial solution, but it still requires manual interaction with each newly created view.
Mohamed-Nassar
Good idea.
Best Regards.
samuelsanf
I agree with @pieterdewaal, Revit should have a Grid/level/Section extension offset parameter from Crop Region.
In some models, changing the 2D line extension of Grids and Levels take long time.
Please add this feature.. I have a project with 300+ dependent views.
I know have the day or two, probably 3 of going to each view and stretching the grid lines back to the crop view so they will fit on the sheet size we are required to use on this project...
Mark.Friis
As an engineer I often link the Architects model into my own model and place the view on a sheet. Often the grid lines are extending beyond my cropped view an into my Legends on the same sheet. Could we please get an option to control the extend of the grid lines outside of the cropped view?
Tags (2)
This looks like a pretty popular topic, @Mark.Friis  and @J.Dirkse . What do you think about combining all three of these?
Mark.Friis
@kimberly_fuhrman-jones thats a great Idea!
J.Dirkse
I agree with it @kimberly_fuhrman-jones.
But more importantly, whether the makers of the two ideas mentioned also agree with your suggestion to combine there ideas! 🙂
J.Dirkse
