Control Array Quantity with Revit.ini
Allow the control of Revit's default Array quantity via the Revit.ini file. For reference, a pair of screenshots.
As you can see, the 'Move To 2nd' radio toggle is controlled via the Revit.ini file. Not so with the quantity (labeled 'Number' in the options bar when using array).
It's frustrating when you want to array 48 different times, all with a quantity of 4 and have to select the quantity and type in 4 every time.
Idea: add a Revit.ini parameter that ties to the quantity. If the parameter is a positive integer, the array command defaults to that number. If the parameter is set to '0', remember the last number that was used.
