Column Height Parameter
There is no height parameter for columns. It would make it much easier to generate/filter takeoffs and schedules if some sort of Height property was available to use.
Walls have an Unconnected Height parameter that makes it very useful to use Revit to find the tallest walls for analysis. It would be nice to have something similar for columns.
12 Comments
HaniTartour
that's right me too . i wish i could to use this parameter for takeoff , schedules and many things also
thanks factory
Guys,
if you are looking the height parameter, in structural column schedule you have system parameter length which is the height of the column. You can also filter by the length(height).Try that..
But you are right it should be a parameter "the height" as for walls in instance properties...
vgmontalban
yes please I would love to have a tag with height as a part of it but need a parameter, it is already schedulable
vgmontalban
I finally found some answer by exploring revit, query close
paulo.belesa
How did you solve it ?
I dont wanna use an structural collumn cause of the heatred " move to bottom" of foundation , another stupid way to do things in Revit.
taiane.bohrer
It seems that this issue in Revit have not been solved yet. I also wants to schedule columns height but not finding a soluition yet. Did you solve it?
paulo.belesa
No, still no Luck
vgmontalban
Yes I have solved it already you can add a reporting parameter for the
height of columns.
samin.hindic1
If  you open column as family, you put dimension on its height in elevation view, set length parameter on this dimension and define this parameter as instance and reporting parameter, then it will be visible in the project when you pick column.
pascalfurrer2456
Die Werte "Höhe oben" und "Höhe unten" fehlen in der Stützen Familie. Bei der Geschossdecken Familie sind diese Wert vorhanden. Für die Auswertung in einer Bauteilliste wären die Werte überaus wertvoll.
Imagine having a BIM software where you cannot extract the length of columns easily, lol
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-height-of-Stru...
Autodesk should just add the built-in parameter (that is available in schedules....) like they do everywhere else? Why hide the data and make a simple thing so hard to obtain for everyone? Ridiculous.
