Dear Developers and Revit Users Colleagues,
I am writing you to kindly request access to the Unbounded Height room system parameter data via the Color Scheme.
Accessing this data will streamline the production of a Room-height floor plan deliverable by using colors connected to this changeable data.
This will reduce the time for preparing a straightforward deliverable without having to use a Ceiling Plan which needs to be annotated by placing spot elevations on each ceiling, or by maintaining a series of view filters displaying different colors per height which requires updating every time a change in height occurs.
Our current workflow was to create a shared parameter called Ceiling Height applied to the Room and combine it with a Dynamo Routine that transfers the Data from the Unbounded Height system parameter onto it.
Would you please support this idea?
