cancelar
Mostrando los resultados de
Quiere decir:
Changing Room tags so leader doesn't appear when moved outside the space
With the new change in Revit 2023, reverting back to the original or improving how the leaders work when a room has moved.
When I move a bank of rooms the tag automatically turns on the leader but losing host to the room origin. When I move a bank of rooms I need the room tag to follow and not automatically turn on a leader.
Original idea here
https://forums.autodesk.com/t5/revit-ideas/room-tags-amp-leaders/idc-p/12037568#M52187
4 Comentarios
El estado se ha cambiado a: Accepted
@katiedickinsonn ,
Thank you for posting this as an Idea. This is already a known issue (bug) that our teams are currently working on.
-Kimberly
o-m-d_nl
When placing roomtags, de roomtags wil automatically add a leader.
When i turn the leader of, the tag will replace itself on the border from the room. When i move the tag to the center of the room, the leader automatically turn on again.
Please fix the asap.. this kinds of errors are not acceptable.
Etiquetas (4)
@o-m-d_nl ,
This sounds like a bug. What version of Revit are you using?
It would be nice if tags had a toggle function to stay where they were placed or move along with the element they're tagging. We're having issues with tags moving around a lot when rooms get adjusted and then end up overlapping things or moving far away. Can we get a function to toggle if the room tag dynamically moves with the room or stays put where it was first placed?
Enviar idea
