Change level of fittings without changing the location
Ability to change level of fittings without changing the location as for instance and for selected network.
For pipe, duct, tray and conduit fittings.
3 Comments
Martin__Schmid
Marking this as implemented.  The problem articulated in the idea has been resolved as of Revit 2020.  If you modify the Level parameter value of a fitting, the element does not move.. rather, the "Elevation from Level" parameter updates relative to the newly selected level.
Tarek_K
Status changed to: Gathering Support
Tarek_K
