Show only
Search instead for
Submitted byAnonymouson08-20-202004:59 AM
Status:
Gathering Support
Change Hardcoded Titleblock Sheet Name Parameter from single line text to Multiline
There nothing worse than having a project browser with long names with large spaces. Instead of hitting space bar 100 times to get the text in the right place a simple multi line parameter should hopefully do the same job.
I completely agree, but I do have a slightly better workaround for you. You can insert a carriage return in a single line parameter. The way I know to do it is copy/paste two lines of text from a text editor (like notepad, not a word processing program). Then i delete the added text and leave the return. I think you can to it from a Revit text box too.
Maybe someone here knows a unicode shortcut for whatever this character is.
