We rarely want to purge all unused elements from a model. Typically we only need to purge specific element categories or types from the model.
Currently when launching the "Purge Unused" tool, the default selection option is "Check All". We typically need to first click the "Check None" button each time and then select only the specific elements that we actually need to purge from the model.
The default "Check All" setting greatly increases the chance that users will forget to first click the "Check None" button and will purge the model of all standard template content not yet in use. This happens on a regular basis even with proper user instruction.
