cancelar
Mostrando los resultados de
Quiere decir:
Category Tags should work like Multi-Category Tags with a type dropdown
Category Tags should work like Multicategory Tags with a type dropdown.
When you tag an electrical fixture (for example) with an Electrical Fixture Tag, you are locked into using whatever tag is set as the default or last used ElectricalFixture tag.  BUT, if you are tagging the same device with a Multi-Category Tag, you get a dropdown list in the Type Selector that lets you select from all the loaded tags WHILE you are tagging.
It would greatly improve (speed up) the process if the normal category type tags worked that way.
2 Comentarios
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
El estado se ha cambiado a: Archived
Enviar idea
