I would like to create cable conduits as cable bundles. Imagine creating a conduit with space for 10 cables inside going from point A to point B. The 10 cables will then spilt out from the conduit at Point B and connect to different equipment. Now cable is expensive and I would like to count the meters of cable needed in total. Revit should now give me the length of the different cables taking into account the running cable length within the conduit. At the Moment Revit cant give me this length so I need to draw each cable individually. Yes parallel conduits helps a bit, but because of different obstacles and the conduit path going in X y and Z directions, and parallel conduits cant bundle the cables, this is not of much help.
