Bottom of Pipe Tag
Bottom of Pipe Tag
Please create or access the top/bottom of pipe as a usable parameter for tagging. It's available for Fabrication components, why not for regular Revit pipe? The spot elevation tool is our only current workaround, but we cannot effectively combine that data with a pipe tag that presents other information.
Tom
14 Comments
patilST
Need to add Bottom of Pipe in revit for taggin.
gbeath
You can use the spot elevation tool and have it report the BOP.
This works great for me as i can tag pipes that cross and show the elevations at that spot.
Give the ability to get the Bottom of Pipe Elevation, and have multiple leaders like with annotations, for objects at the same elevation.
patilST
HI..
Greetings...!!
Direct BOP tag is not possible in revit..I would suggest you to use Spot elevation to place BOP as tag is element base any value in tag to element is same at all elevations.. spot elevation give you point specifc value..if you move value will also change along inclined pipe if it has slope.
Hope this solves your issue...
Always ask if in doubt..
Sunil
Right now the offset of the pipeline is calculated from the centerline (placeholder). But in reality (in the field) it's always calculated from the bottom pipeline, bottom of the pipes inner circle or top of the pipeline. Right now we always need to add the radius to the offset to get the right minimum or maximum height. If the radius has to be changed, we also need to adjust the heights of all the pipelines. If we could set the placeholder as bottom, inner bottom or top of the pipeline, it'll should save a lot of time and prevents miscalculations.
We also have full-automatic excavators to dig sleeves for the pipelines, but they need the bottom of the pipelines in DWG. Right now we export a DWG from Revit and need to offest all centerlines with the pipe radiusses to and reconnect them all in AutoCAD. This is very time consuming and unnecessary if we could set the pipelines centerline as bottom of the pipe.
It is already possible to adjust the Horizontal and Vertical Justification, but we would like to see the placeholder moves with it. If its possible, it would be great to have all horizontal pipes as bottom and all vertical pipes as center of the same system. We hope this will be added to the next update. It would really improve the BIM to Field (and back) workflow.
If we want to tag the actual center elevation, a workaround could be to add a calculated parameter, but this won't work for round ducts (creating a new type in the family would work, but
When creating a Duct tag, the following parameters are available:
Bottom Elevation
Start Offset
End Offset
Top Elevation
Missing parameter:
Offset (Center elevation)
For Pipes the following parameters are available when creating a tag:
Start Offset
End Offset
Missing parameters:
Bottom Elevation
Top Elevation
arthur
our company has been looking for this solution as well.
one tag to show pipe size, system, slope, and bottom of pipe elevation from finished floor as shown below.
Thanks for combining these ideas
EckdahlRD
I would also be happy with a native parameter for pipe centerline and invert (inner).  This would greatly improve efficiency and reduce the risk that someone using a spot elevation tag doesn't pick the wrong line (like the outside of the pipe instead of the inside).
gbeath
I agree a separate function for just pipes would be better as i have mistakenly tagged a pipe thinking it was tagging the bottom, when it was doing the center line.
Martin__Schmid
We're closing this as implemented as there were changes in 2020 release enabling "access the top/bottom of pipe as a usable parameter for tagging."
If there are additional separate / related requests, please feel free to create a new Idea.
Tarek_K
Status changed to: Gathering Support
c.barribaud
How to add NGF into tag without using dynamo or spot elevation ?
Tarek_K
Forma Design Contest
Technology Administrators
