Show only
Search instead for
Revit should make it possible to adjust the bolt lengths and grip lengths if they are selected from the fabrication elements tab only. At the moment the only way to select and edit bolt lengths is if you add in a base plate with a column.
Behind the Revit steel fabrication elements it is mostly the Advance Steel logic implemented. The Bolt Length and Bolt Grip values are greyed out because they are automatically calculated, based on some database table values, and they are there only for information purposes.
Here is an AKN article that explain how the Bolt Length and Grip Length is calculated in Advance Steel.
