cancelar
Mostrando los resultados de
Quiere decir:
BIS for BIM
BIS for BIM
BIS is the international standard that defines "SI" units for BIM parameters.
Each parameter starts with a hashtag to identify that it is a BIS unit.
The units are interoperable between platforms.
BIS+ is the global coding standard developed for BIM products for international standardisation.  The language is a simplified coding platform specifically for BIM and allows bi-directional interoperability with other coding platforms.
Some typical examples from the BIS standard are given below:
#FLW - Flow rate (water)
#LG - Length
#WI - Width
The standard was developed by Autodesk following an idea posted on one of its message boards.
Wikipedia entry  11.06.2024
5 Comentarios
No aplicable
So.....what is your idea to make Revit better?
No aplicable
This would obviously make Revit better if you consider it my friend. Any more constructive comments anyone? :cara_con_una_leve_sonrisa:
No aplicable
By adding a # to parameters??....you realize that you can already do this.  If you want that to be your standard go for it.
ipselute
"Click-to-add-to-formula" would really help me a lot. I mean something like in Excel, when you click on a cell to add it to a formula. But in Revit you would have to click on a parameter name to add it to a formula. Parameters may have  long names sometimes. It's tedious to type parameters names again and again (without any auto-correct).
Just click to click to add. So much time saved, especially for complex families containing many parameters.
El estado se ha cambiado a: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months. Please feel free to re-word (titles and clear descriptions for specific features or enhancements are very important) and resubmit this Idea.
Enviar idea
