Currently it is pretty cumbersome to add relative path to an url parameter, you have to /[Model Folder]/[Sub-Folder]/[FileName and extension].
- Why do we need to write the current [Model Folder]. If the folder is renamed, links don't work anymore. Common relative path use file location and don't need this.
- When you work on a central model relative path is made from your local file path. It would be better to consider it as relative from central file path.
- It would be nice that it handles previous folder as usual relative path.
Example :
Central file path : CaseFolder/RevitProject/0000_ProjectName_R17.rvt
Linked file path : CaseFolder/Documentation/xyz.pdf
Relative path : ../Documentation/xyz.pdf
