Being able to display the order of the levels in pull-down menus of the properties panel in their correct spatial order
The  order in which the different levels are displayed in the pull down menus of the properties panel (i.e. walls base constraint , wall top constraint , stairs levels constraints ,...) is hardwired  , always placing the lowest level at the top and the highest level at the bottom .
I think it would be very useful if one had the option of reversing  this display . so that it matches the spatial order in which you are modeling of the elements .
It may look as a minor issue , but my opinion it would make the modeling  much more fluid . The way it is working now feels very contra-intuitive.
4 Comments
krzystoff
Agreed.  Also, while we're at it, maybe the BASE and TOP constraints for families and underlays, etc. should be arranged in the right order too, with BASE below TOP
wr.marshall
dplumb_BWBR
Agreed.
Even worse, the "Paste Aligned to Selected Levels" sorts it Alphabetically
martijn.lugthart
I agreed.
It makes no sence that you place your levels upwards from 0 or 1 and the it shows it the otherway around in the pull down menus.
