Be able to use Multi Leader Tag: Host Count in a Calculated Parameter Formula
Basically just as the subject line reads.  I want to be able to use the Host Count parameter in a tag's calculated formula parameter within a label.
1 Comment
aallo_ville
This would be very helpful when presenting e.g. multiple air terminals in a same tag. You could have it written e.g. "Host Count * Flow" in a parameter and then you could show the flow sum of the tagged devices. Now the "Host count" cannot be a part of calculated formula.
