cancelar
Mostrando los resultados de
Quiere decir:
automatically hide unreferenced view tags on sheets
i use views all the time to study building elements.  maybe half of the views generated end up on sheets.  seeing unrefenced view tags on sheets drives me crazy.  sheets should be linked to the print settings so that if unrefenced view tages are turned off then they should not appear on the screen view of the sheet.   i shouldn't have to rely on a check box to know how the sheet will print.
sheets should show on screen how the sheet will print as defined by the print settings.
(i do eventually purge out unused views to clean up the model)
3 Comentarios
LeeUUSLM
This would work better if it was a tick box function similar to the one that allows you to see crop regions.
"Unreferenced View Tags Visible"
whitneyludvik
You can achieve this with a filter.  Because views that are on sheets have a value in the sheet name or sheet number parameter, you can use that parameter to filter unplaced views.
emorrisCX4Z7
Same request for section views and elevations.  Hiding unused elevations is annoying as multiple components need to be hidden to completely hide these from view in sheets.  It would be a great tick box to toggle them off and on in the view settings for sheets and therefore something that could be used in View Templates too.
Enviar idea
