The current View Break (from the Plan Crop Region) is great for showing separated areas (like two distant parts of a plan) on one sheet. But after creating and adjusting the break, we still have to manually draft a break symbol and add text/dimensions to show the true distance between those areas. This is time-consuming and a bit frustrating.
Request:
When we create a plan View Break, Revit should automatically:
- Place a standard break/gap symbol at the split.
- Add an annotation that shows the true physical distance that was “removed,” and keep it updated if the View Break changes.
- Optionally control that annotation/symbol with a Yes/No instance visibility parameter.
