Autodesk Viewer, Uncheck "Section Box" in 3D view
Only part of the Revit model is displayed in Autodesk Viewer, when 3D view in Revit has activated the "Section Box" option.
I suggest to insert check/uncheck "section box" option in the viewer, otherwise every time we will have to call the bim specialist to fix the problem, by unchecking "Section Box" in view properties in Revit.
Thank you.
