Auto Join Geometry
Auto Join Geometry
We definitely need a tool, which can automatically join the geometry. Yes, we have join tool in Revit, but we can apply this tool just for on pair of elements in one moment and for a large project is this tool hardly usable. We need a tool where we can set up for example: Join all walls into all floors in project, and it will do this immediately and it will be stable for large project. It should save a lot of time.
1 Comment
benschilders
@lukas-tunka  Good idea and lets pray autodesk will pick up on this.
Found this idea before wanting to write it myself (always use the search function before posting duplicates people),
i would like it to be a option in the  options UI settings though.
So that the user could choose to always auto join elements or not depended on there preference.
(still think most people would use autojoin because most real life buildings are connected elements you know 😅😉 )
And it probably isnt even to hard to code because you can allready join stuff so now it just need to be told to always join instead of having to manually do that.
Also it would be nice to combine this with having more piorities then the 5 existing ones, and then maybe on material level instead of on component type settings (I know this is just how Archicad works but that is also where i got the idea from )
  See this idea post and vote for it if you like it:
https://forums.autodesk.com/t5/revit-ideas/compound-structures-material-priority-instead-of-layer-pr...
Have a nice weekend all !
