cancelar
Mostrando los resultados de
Quiere decir:
At import window: Have an option for Pre-clean up dwg files before importing
There are many hidden bugs and problems at Revit if we import a dwg file without cleaning (such as purge, explode, flatten)
Before importing dwg file Revit should have an option to purge and flatten and other clean up jobs which are listed at here.
for example, I imported a dwg Survey file it has many problems such as:
1- drawing doesn't flatten and vertical Cad file shows at the elevation and sections!
2- after importing without purge some of the dwg file's text boxes have font style problems (see below image)
3-some of the cad blocks after importing change to weird shaped (see below image)
Original cad drawing is like below
but after importing to Revit it shows like this
for more information see related topics
https://forums.autodesk.com/t5/revit-architecture-forum/dwg-files-has-weird-text-after-importing-in-...
https://forums.autodesk.com/t5/revit-architecture-forum/at-hide-line-visual-style-revit-shows-the-hi...
3 Comentarios
No aplicable
 If the dwg file isn't flattened it will cause this problem
dplumb_BWBR
Sorry, but I don't think it should be Revit's responsibility to clean up AutoCAD crap (bugs)
No aplicable
It is not AutoCAD's bug. If you open AutoCAD the file is ok and Revit should open the file the same as it is!
maybe it is an incompatibility of these softwares.
Enviar idea
