cancelar
Mostrando los resultados de
Quiere decir:
Assigning Typical Parameters for Steel Connection
Huge problem I have with steel connections is that even if I spent time specifying every parameters if I insert a new connection of the same type (let's say Clip Angle for example) I will have to re-enter all the parameters.
I would like to be able to specify the parameters once and be able to make it as a type.
Let's say it's Clip Angle Type A. I will to be able to set parameters for my Clip Angle Type A.
If I ever need to make modifications I would only have to change the parameters once for Type A.
If I have to use another type of Clip Angle then I would create Type B.
This way I could change from one type to another easily and update all the same "Type" at once.
1 Comentario
ipselute
It would be great to be able to create families from standard steel connections. A big time saver. Maybe could use it again in other projects. Like a catalog of standard details for steel connections.
Enviar idea
