cancelar
Mostrando los resultados de
Quiere decir:
Area Scheme displayed in Area Schedules
To be able to easily identify which Area Scheme an Area Schedule belongs to.
The area name of a new schedule gets the Area scheme in brackets, until someone renames the title and cuts that out. Then nothing!
You can use highlight in model button (slow and cumbersome), There just needs to be a read-only parameter in the Identity data that displays the scheme it belongs to.
In Revit 2018.1 this has been made a little easier with schedule browser sorting, but if you aren't sorting by this method, then it is yet another workaround.
Tags: #Scheduling, #AreaSchemes
3 Comentarios
jkidder
Its disappointing that this information is still concealed.  While it can be figured out using Dynamo, that is not intuitive for many users and is an additional step for all users. The area scheme should be easy to find in the properties or in the schedule field edit dialog.
nmcclure-TCA
This is a seriously needed modification.  Users should NOT have to run a tool like Dynamo to 'reveal' something so fundamental, and unchangeable.  Many users change the name of the schedule to remove the Scheme prefix, simple to make the views more readable in the project browser.   The Associated scheme should be listed in the FIELDS dialog.
fkhan99KQN
Ping Autodesk. All we need is a parameter under identity data to display something that revit already tracks!
Enviar idea
