annotation crop - follow edited view crop
Make the annotation crop an offset of  edited view crops. Or make it an option. We have to manually hide all of annotations beyond the view, as the annotation crop is just a rectangle beyond the extent of the shaped view crop.
20 Comments
doni49
When you edit the view crop, the annotation crop boundary follows at the same offset distance.  And yet you can still edit the annotation crop boundary too.
lionel.kai
EDIT: @doni49 I think the OP means having a non-rectangular Annotation Crop when he talks about "following" the Crop Region (following the shape, not following a change/drag) because he mentioned rectangular vs. "shaped" at the end (and his example image).
BTW, this idea was posted as a comment to:
http://forums.autodesk.com/t5/revit-ideas/non-rectangular-scope-box/idi-p/6330700
which is under review, though I'm not sure if the "non-rectangular annotation crop" part of it is being reviewed or not...
Annotation crop region needs to follow the path of crop region!
aaron.jonesSAP83
For clarification, are you saying that, if I create a callout that is not rectangular, the annotation crop shape should be the same as the non-rectangular crop region shape?  Could you provide some more detail about what it is you're looking for?
That's exactly what I am looking for aaron
m.voss.alvine
Hazem.Elamir
please give me an option to edit the annotation crop to be like the view crop
many thanks
jswoolley
Yes, it does seem strange that the view crop can be rotated and redrawn, while the annotation crop always remains a rectangle. I like your idea, but wouldn't it be just as easy to hide a couple grid lines, or move the heads closer to the view window?
Hazem.Elamir
YES, you are right but there are some data you want to hide by using the annotation crop boundaries and this may be repeated in some areas , so it would be faster to edit the annotation crop boundaries
cbcW7RG3
Hazem, rather than keeping on modifying the grid lines, you can simply adjust the gridlines in one view, then hit propagate extents, and select all of the other views you want the grid lines to match on.  Quick and easy.
Hazem.Elamir
dear @cbcW7RG3
the point is not adjusting the grids
grids and other tags or 2d data set hidden automatically when it become out of the crop
so we need to be able to make the annotation crop follow the crop boundary to get it more fast
filip.kabelis
We need an option to fit annotation crop to custom crop boundary!
Radish_G
This is one of the most important requirements.
psubink
It seems like most of the commentators on this post work in the Architecture side.  As a MEP guy, when I link Arch or Struct into my model, your gridlines won't crop and I can't adjust them like you can.  Yes, I know I could copy/monitor them, but we don't do that for every project.
Great idea Dave - I hope this gains more traction soon.
wrtetro
Why is this not a thing yet?  Drafters lose a lot of time checking sheets for what look like floating tags.  Also, make grids adjust to the crops.  This would be another huge time saver.  Propagating extents does not work with plan regions applied.
lionel.kai
@wrtetroI think you meant "with crop regions applied"? This would also help: Propagate Extents of Grids without turning off crop
dzanta
This is a submittal from one of my awesome students....
We would like to have the Annotation Crop region mimic the shape of a custom callout crop region or be able to make your own custom annotation crop region independent of the crop region.
Things that make you go hum....
Tags (2)
anis.choudhury
Annotation crop filter per view template would be extremely useful. Often times I need the crop to hide the cropped rooms space names, but I want to be able to extend the tag information as far off the drawing onto blank space as much as possible for drawing clarity. I would welcome this function in Revit with open arms because of all the workaround one must do per drawing hiding unnecessary space names or annotations.
User5CYX5R
Hi Autodesk
Hide “Linked in Text” Outside Customized Crop
We are working on a large hospital and need to do thematic views of a passage with a complex from.
We need to document the passage only on a sheet showing only text regarding the passage.
We are able to show only the part we want by customizing the crop view, but we are not able to customize the annotation crop. This has the Issue that a lot of text next door is showing that we want to hide.
Is there a workaround to hide the text? Like placing a region? We can’t do Hide in view because the annotations are linked. The Annotations is tags from a Furniture Family.
Kind Regards
Kobus vd Berg
pieterdewaal
Few things look as ugly as a seperate tenant fire protection plan in a centre with a cropped view showing signage and equipment outside of the tenant area 🙈
