Angular Dimension options. Results are different when dimensioning Families from linked files
I did create a a cable route and added angle dimensions to it. Then I loaded a linked revit file into my host file. The linked file also contained cable routes. But I could not add the same Angle dimensions to the linked cable routes:
For Illustration here: Its not possbile to add 90° to the other side. An the host cable route does not allow for 270° to be added. A workaround here would be to use reference lines, but actually it would be much better to have an option to decide how the angle should be measured.
