When placing angular dimensions, it's really frustrating that we can't edit witness lines after the dimension has been placed.
Especially for grids or curtain grids where we might need a continuous dimension, it can be quite cumbersome to place dimensions. God forbid you click beside a line and the dimension stops, forcing oyu to either create seperate strings or start over.
Or when you select the wrong element, you'll have to delete the dimension string and start over.
Adding the "Edit Witness Line" functionality would solve this problem.
